TwinTurbo.NET: Nissan 300ZX forum - Heat in florida posed a problem with the inverter. It has
Subject Heat in florida posed a problem with the inverter. It has
Posted by Ash's Z (In Progress) on May 13, 2004 at 10:44 PM
  This message has been viewed 36 times.
In Reply To About your zpc... posted by Xlr8tt on May 13, 2004 at 02:13 PM
Message an internal thermal shutdown switch which was killing power when the temps in the car were over 120 degrees.. This was never a problem while driving, but if the car was left in the sun for a little while, I wouldn't be able to turn it on until I ran the car and AC for a few minutes.. So I installed two additional cooling fans into the inverter - drilled breather holes in the casing of the inverter and that problem was fixed. I've had the 30GB HDD in there as the system drive for over three years now and the 40GB drive is about two and a half years old. Haven't had any problems out of the system for almost four years now.
[ ashleypowers.com ]
[ agpowers@bellsouth.net ]
[ Zemulator Information Sheet ]
[ Z1 Motorsports Website ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
