TwinTurbo.NET: Nissan 300ZX forum - No..On solid cam, cam lift = valve lift when eveything is
timz
on April 22, 2004 at 7:25 AM
Your lift on the solid cams are off because you
posted by AzHeat
on April 22, 2004 at 02:04 AM
up to operating temp. The expansion of the valve, lifter, shim, cam, valve lock, retainer etc will take up the lash. That's why you need valve clearance and it's measured when cold.
Need some advice from the valvetrain experts here >>
timz
16:12:28 04/21/04
im not sure, but are you selling your old cams? (n/m)
NA300zx (OH)
16:17:00 04/21/04
Sorry Dave, they were sold. (n/m)
timz
16:21:33 04/21/04
This won't answer your question, but I'm trying to learn
Scotts94z32
16:55:27 04/21/04
We don't have rocker arm :)..it's direct 1:1 ratio bucket
timz
17:30:26 04/21/04
That's good info - I've learned today. I thought a 50 thou
Scotts94z32
17:55:04 04/21/04
50 thou will be way too much for the valve clearance:)
timz
18:09:43 04/21/04
isnt there a little shim under each bucket?
ScubaSteve
19:24:22 04/21/04
No shims, healthy lifters self-adjust (n/m)
Chip(GMS Racing)
21:15:29 04/21/04
Re: Need some advice from the valvetrain experts here >>
nixit
17:00:52 04/21/04
Thanks for the advice nixit:)
timz
17:38:20 04/21/04
no what he means is its better to have more clearance than
ScubaSteve
19:30:17 04/21/04
I am going almost the same route you are but
AzHeat
01:59:33 04/22/04
AzHeat
02:04:11 04/22/04
No..On solid cam, cam lift = valve lift when eveything is -
timz
07:25:45 04/22/04
Have you been to Tomei website ? I suggest you do because
AzHeat
08:52:17 04/22/04
You're right..I just figured this out
timz
09:39:39 04/22/04
I was thinking the same thing, how much you were
AzHeat
15:33:18 04/22/04
