TwinTurbo.NET: Nissan 300ZX forum - When using maf's direct air f's up the signal to ecu
Subject When using maf's direct air f's up the signal to ecu
Posted by Mike@AeroMODIFIER on April 07, 2004 at 5:41 PM
  This message has been viewed 81 times.
In Reply To where'd you read that? (n/m) posted by ni[X]it on April 07, 2004 at 05:31 PM
Message and can cause acceleration problem, and bad hesitation. With speed density you wouldn't have to worry about the direct air , cause the stand alone can control right A/f ratios for both sides of motor. And is possible to use ram air effect to help, kinda how supra uses it (when remove passenger headlight).
www.aeromodifier.com
The Finest in JDM and J-Spec
Aero Tuning, Wheels, Performance products and HID lighting.
(610)268-2375
Info@aeromodifier.com
