TwinTurbo.NET: Nissan 300ZX forum - remember my bad gas mileage problem?? did some searching >>
Subject remember my bad gas mileage problem?? did some searching >>
Posted by stockplayerz (NYC) on April 06, 2004 at 3:49 PM
  This message has been viewed 209 times.
Message and found out it could be a plethora of things. one possibility suggested was the PCV valve. i've found that some symptoms include bad gas mileage, unstable idle, and dipstick popping out. the only symptom i have is poor fuel economy. so the pcv valves should be okay right? not sure what else to check. one time i did smell fuel after a hard run but i don't see any visible leaks on the dampener nor the regulator. fuel filter and O2 sensors are new. tire pressure is within spec. i do rev past 3K but i don't floor it from light to light.
what do you think the likely probability is? any info would be much appreciated. thanks guys.
mike
zxredline@yahoo.com
