TwinTurbo.NET: Nissan 300ZX forum - chris, when u get the motor fixed and u go for the 1st drive
Subject chris, when u get the motor fixed and u go for the 1st drive
Posted by Borg79(ON) on April 03, 2004 at 5:20 PM
  This message has been viewed 21 times.
In Reply To Day one: posted by Chris(NJ) on April 03, 2004 at 05:18 PM
Message you will realize all the pain and hard work is worth it in the end :) I went through the same thing :)
-"Chains baby, chains.......Z will grip like a champ. (n/m) - Wolf [Pittsburgh] 14:56:58 05/10/00"
How to Check Turbos: "1st remove exhaust and pre-cats. Then fire that mother up, rev it to at least 5000 rpm and then stick your finger into the hole on the back of the turbo. If the turbine grinds your finger down, then your turbo is working. If your finger gets ground off farther than the second knuckle, then your turbos are good for at least another 60k miles! Don't forget to check both sides." -I am Z-ing Double
-"The world's two biggest mysteries: The meaning of life and fitting the Howe radiator into the Z..." -Seedyrom, circa 2000
