TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Any other Maintenance I should do while replacing th
Subject Re: Re: Any other Maintenance I should do while replacing th
Posted by had rice? on January 25, 2001 at 1:09 PM
  This message has been viewed 27 times.
In Reply To Re: Any other Maintenance I should do while replacing the cl posted by aaron91tt on January 25, 2001 at 01:03 PM
Message : well, i did the clutch slave/master cylinder's and my flywheel at the same time to keep labor to a minimal for future references. if you eventually want a flywheel, do it now, it'll be the coolest thing you've done so far(unless you have 18's)!
I would also gut the precats (or replace with downpipes), rear main crank seal, check the coolant lines at the turbos, throwout bearing, pilot bushing, & rear transmission mount.
Later,
Phuong - www.EatRiceZone.com
Rice Land!
