TwinTurbo.NET: Nissan 300ZX forum - Shimming Oil pump pressure regulator. Does anyone
Subject Shimming Oil pump pressure regulator. Does anyone
Posted by AzHeat on March 30, 2004 at 11:18 AM
  This message has been viewed 548 times.
Message have any experience with shimming with washers the pressure regulator on the TT oil pump? I did my search and came up near empty on here .
I added three washers to my new oil pump regulator which amounts to 1/4 inch shim against the spring. Not sure how much more pressure that will add to the engine. I want to add 10 - 20lbs more oil pressure. I think Ash said he added 3/8 of inch and the "PeaceMaker" was making about 100 psi of pressure at 3000rpm. Not sure if that is the correct numbers.
I haven't attached the oil pan yet. I can change it anytime the amount of shimming.
Thanks,
