TwinTurbo.NET: Nissan 300ZX forum - The structual damage is a mere result of electrical failure.
Subject The structual damage is a mere result of electrical failure.
Posted by SooperZ95 on March 21, 2004 at 2:15 PM
  This message has been viewed 40 times.
In Reply To Except diode breakdown is not normally destructive provided posted by therin (Plum) on March 21, 2004 at 01:55 PM
Message Also because the reverse break-down voltage is typically very large it takes only a very small amount of current to exceed the power capabilities of the device. Hence the diode would "potentially fry" as I put it before.
You are absolutely right, if the current is limited in the reverse breakdown region the device will not be damaged. In fact Zener diodes are made to operate in the reverse breakdown region.
