TwinTurbo.NET: Nissan 300ZX forum - Well i am not having any problems with the ECU, I just
Subject Well i am not having any problems with the ECU, I just
Posted by Borg79(ON) on March 21, 2004 at 1:10 PM
  This message has been viewed 28 times.
In Reply To They do have a reverse break-down voltage. posted by SooperZ95 on March 21, 2004 at 01:03 PM
Message noticed this while I had it apart. I will clean up the black burnt resin and resolder it in case the solder cracked from the heat. My only concern is, will this diode continue to get hot like this, or will it be OK???
-"Chains baby, chains.......Z will grip like a champ. (n/m) - Wolf [Pittsburgh] 14:56:58 05/10/00"
How to Check Turbos: "1st remove exhaust and pre-cats. Then fire that mother up, rev it to at least 5000 rpm and then stick your finger into the hole on the back of the turbo. If the turbine grinds your finger down, then your turbo is working. If your finger gets ground off farther than the second knuckle, then your turbos are good for at least another 60k miles! Don't forget to check both sides." -I am Z-ing Double
-"The world's two biggest mysteries: The meaning of life and fitting the Howe radiator into the Z..." -Seedyrom, circa 2000
