TwinTurbo.NET: Nissan 300ZX forum - I did the same with a rotary tool (air powered dremel) with
Subject I did the same with a rotary tool (air powered dremel) with
Posted by Borg79(ON) on March 09, 2004 at 10:31 AM
  This message has been viewed 34 times.
In Reply To How to get a plenum and other bits *really* clean... posted by Dallas DamonZ on March 08, 2004 at 10:40 PM
Message a wirebrush attachment. I didnt even have to remove the plenum from the car...just a little bit of a pain to clean all the little aluminum fragments :o
-"Chains baby, chains.......Z will grip like a champ. (n/m) - Wolf [Pittsburgh] 14:56:58 05/10/00"
How to Check Turbos: "1st remove exhaust and pre-cats. Then fire that mother up, rev it to at least 5000 rpm and then stick your finger into the hole on the back of the turbo. If the turbine grinds your finger down, then your turbo is working. If your finger gets ground off farther than the second knuckle, then your turbos are good for at least another 60k miles! Don't forget to check both sides." -I am Z-ing Double
