TwinTurbo.NET: Nissan 300ZX forum - When does the oil circulate? High press. or low press?
Subject When does the oil circulate? High press. or low press?
Posted by Borg79(ON) on March 03, 2004 at 6:04 PM
  This message has been viewed 40 times.
In Reply To change the pressure switch to a temp switch posted by TARGETZ on March 03, 2004 at 05:16 PM
Message This may be in place, because of the pressure drop of the oil going through all the other crap it has to go through. Might have adverse affects...PS: When Im doin in T.O in the next few months we'll have to meet up. Theres only ~3 or 4 z's which I rarely see in this city :)
-"Chains baby, chains.......Z will grip like a champ. (n/m) - Wolf [Pittsburgh] 14:56:58 05/10/00"
How to Check Turbos: "1st remove exhaust and pre-cats. Then fire that mother up, rev it to at least 5000 rpm and then stick your finger into the hole on the back of the turbo. If the turbine grinds your finger down, then your turbo is working. If your finger gets ground off farther than the second knuckle, then your turbos are good for at least another 60k miles! Don't forget to check both sides." -I am Z-ing Double
