TwinTurbo.NET: Nissan 300ZX forum - I doubt 12 psi of boost will blow a head gasket by itself. (n/m)
AzHeat
on February 22, 2004 at 7:13 PM
I installed bigger injectors+chip then I blew the headgasket
posted by PLEAZURE in CA (SD)
on February 22, 2004 at 02:24 PM
PLEAZURE in CA (SD)
14:24:13 02/22/04
Sorry to hear, Hope you can put it all back together (n/m)
aZiator
14:31:12 02/22/04
Re: I installed bigger injectors+chip then I blew the headgasket
SirpriZ
14:57:05 02/22/04
I think I will go with K Watanabe in Lynwood $2800 installed
PLEAZURE in CA (SD)
15:45:51 02/22/04
Make sure you find your gremlin before you do the>>
SirpriZ
15:54:57 02/22/04
$2800 J-Spec installed .. new timing belt included
PLEAZURE in CA (SD)
16:38:51 02/22/04
i see the problem in the 1st paragraph. (n/m)
Chris(NJ)
15:58:48 02/22/04
Re: i see the problem in the 1st paragraph.
Magnum
16:02:02 02/22/04
Ya it's a little bit too late now
PLEAZURE in CA (SD)
16:26:29 02/22/04
thats wrong...maps are changed when it detects pinging
cant_z_me(back in business)
17:50:50 02/22/04
The program will retard timing when detonation is detected.
AshsZ
22:42:54 02/22/04
You can do a stock rebuild for under $1000, I'm doing it
mpbond
16:20:35 02/22/04
125-130? isn't 128 the lower limit? what about leakdown? (n/m)
Scotts94z32
16:25:35 02/22/04
Before you say it's a blown Headgasket. do another
Yuengling
17:43:07 02/22/04
Thanks .. nice Z you got there (n/m)
PLEAZURE in CA (SD)
17:52:11 02/22/04
Thanks. :) (n/m)
Yuengling
17:58:48 02/22/04
If he has steam coming out the exhaust and losing coolant
AzHeat
18:13:47 02/22/04
sometimes..yes. but that wasn't the case with mine-->
Yuengling
19:13:34 02/22/04
It does sound like you have a blown head gasket.
DVDBURN (MD)
18:29:53 02/22/04
I'm seriously thinking it's a blown headgasket. Does
SpeedyZX
18:49:18 02/22/04
Just so this is clear, AN ASHSPEC PROGRAM SENT TO CALIFORNIA
AshsZ
19:07:11 02/22/04
Cool beans. How do you account for our crappier octane
SpeedyZX
19:20:27 02/22/04
I'm sure their low or mid grade gasoline is the same
AzHeat
19:26:37 02/22/04
It is tuned on 89 octane fuel (which is our mid-grade)
AshsZ
20:13:08 02/22/04
No need to jump to conclusions of what caused it. (n/m)
AzHeat
19:19:32 02/22/04
If you're implying that I think Ash's ECU caused it, then
SpeedyZX
20:15:21 02/22/04
We pay 2.38 per gallon here in Carlsbad =/ (n/m)
james-lee
21:10:05 02/22/04
Your car overheated and you warped the heads, which caused
AshsZ
19:04:40 02/22/04
I agree with you. same thing happened to my Z. (n/m)
Yuengling
19:16:06 02/22/04
I doubt 12 psi of boost will blow a head gasket by itself. (n/m) -
AzHeat
19:13:15 02/22/04
Just to make it clear, I drove the car for an entire week
PLEAZURE in CA (SD)
20:06:55 02/22/04
Just curious, what are your plugs gapped to? (n/m)
AshsZ
22:18:08 02/22/04
Stock gap .. around 1.1mm
PLEAZURE in CA (SD)
15:10:30 02/23/04
If you had injectors installed, there is good chance
AshsZ
22:14:06 02/22/04
Re: If you had injectors installed, there is good chance
PLEAZURE in CA (SD)
15:27:02 02/23/04
