I have been looking into getting some upgraded injectors while my motor is apart. Once I eventually blow my stock turbos, I will be replacing them with either JWT BB535 turbos or HKS 2530BB turbos I just have a few questions first (pardon my ignorance): Should I go with 555cc or 720cc injectors?Will 720cc injectors fit in a 91 TT without any modification to the lower plennum? With these current mods, will it be ok to run injectors this big until I upgrade my turbos at a later date: *Ash spec "Doolz" intake *Unorthadox Racing underdrive pulley *Hiper cat-back Exhaust *Ash spec ECU (to be upgraded according to what injectors I go with) *Greg Dupre divorced downpipes *2.5" testpipes *Fidanza aluminium flywheel *RPS TT Max Street clutch *A'PEXi AVC-R boost controller *A'PEXi turbo timer *JUN adjustable intake cam gears (exhaust gears on the way) *Ported and polished upper & lower plennum *Ported and polished throttle bodies (I realize may need a SAFC) Thanks in advance for your help.
-=Colby=- 1991 Pearl Black 5-spd Z32 TT Stage X (project car under construction) 1991 Cherry Red Pearl 5-spd Z32 TT Stage V 1996 Super Black 5-spd 200sx with Yellow Trim Stage II (Daily Driver) AIM: ColbyZ20 AOL SN: Colbs19 Check out my photo album for updates at: www.photoisland.com sign on: Colbs19 password:ttnet |
