TwinTurbo.NET: Nissan 300ZX forum - I think because he uses windshield washer fluid because
robo (sebring1970)
on January 30, 2004 at 8:03 PM
Confused...what does the cost of windshield washer fluid >>
posted by I am Z-ing Double
on January 30, 2004 at 07:50 PM
it contains some alchohol, which is also good for mist injection, some glycol, so it won't freeze in the holding tank, and the water itself is hopefully purified or filtered. Plus, it's a pretty blue color.
Water Injection: "Just add water"; 1st trial run.
AshsZ
19:17:08 01/30/04
*inteerrreessttiiinnnnnggg* good luck Ash. (n/m)
Red ZX (Sr. N00b)
19:25:51 01/30/04
cool (n/m)
robo (sebring1970)
19:35:36 01/30/04
OK. Just got back. Running 25psi of boost, 22 degrees
AshsZ
19:44:14 01/30/04
I am Z-ing Double
19:50:39 01/30/04
Windshield washer fluid is being used as the "water" (n/m)
speedr300z (ATL)
19:56:00 01/30/04
hmmmm...maybe that is what he is using (n/m)
Tennyson (ATL)
19:56:26 01/30/04
I think because he uses windshield washer fluid because -
robo (sebring1970)
20:03:50 01/30/04
It will also fight corrosion (n/m)
SeedyROM (ZCON 2K4!)
20:12:24 01/30/04
Good point! With all this brass in the fittings and
AshsZ
20:30:09 01/30/04
Glycol is bad, it behave like sugar and will glue the
northZ
04:09:27 01/31/04
Its been getting down to freezing temps and I dont want
AshsZ
20:08:31 01/30/04
O.K., the freezing/alcohol thing makes sense. >>
I am Z-ing Double
20:33:32 01/30/04
There are no detergents in WW fluid that I am aware of.
AshsZ
20:56:23 01/30/04
the facts;
ni[X]it
22:46:25 01/30/04
really? I'll call this, "every DOGma has it's day" --->
robo (sebring1970)
06:38:02 01/31/04
Yup, it crystalizes in the liver when metabolized. BAD
AshsZ
07:44:41 01/31/04
the glycol shuts down the kidneys (renal), not the liver
robo (sebring1970)
17:51:28 01/31/04
i've had the displeasure of tasting both.
ni[X]it
10:18:31 01/31/04
most washer fluid doesn't contain any glycol, unless it's
robo (sebring1970)
17:25:31 01/31/04
am braking traction in 3rd gear on good tires
HakenTT
20:11:30 01/30/04
Well, I can see why you were able to run a stock ECU
AshsZ
20:19:07 01/30/04
That's true, with H20 it is necessary to run slightly
MikeH(Twin GT35BB Incon Z)
21:04:51 01/30/04
Good idea. This whole H2O thing is great for those of us
IBPimpn(Ca)
21:19:17 01/30/04
Agreed. I have been running H2O injection for over
Glenn (San Jose)
23:14:13 01/30/04
I need to do that. I can only run 13# @ 14degrees
IBPimpn(Ca)
23:27:27 01/30/04
that's counterproductive (n/m)
robo (sebring1970)
20:37:44 01/30/04
3rd (n/m)
RobWR14
20:38:49 01/30/04
wonder what you could do with h20 inj + race fuel (n/m)
RobWR14
20:34:35 01/30/04
what was the outside air temp today? (n/m)
Scotts94z32
20:54:42 01/30/04
That's the amazing part, its like 40 degrees out and
AshsZ
21:51:03 01/30/04
The Buck GN's here run H20 inj. all the time because
21:00:44 01/30/04
you'll have torque gains with more water,
ni[X]it
22:20:11 01/30/04
How do you figure that? More water may loose power
03:15:05 01/31/04
I think its not all about cooling, the volume of the water
northZ
03:58:21 01/31/04
Here is a link to water injection dyno testing
04:11:31 01/31/04
I wonder if someone will jump their ass for using STD
AshsZ
07:49:21 01/31/04
Ah, well in that case I think I will be adding more nozzles.
AshsZ
07:56:25 01/31/04
I am thinking of designing and running a staged
10:08:41 01/31/04
I have considered doing that too. But I'm leaning more to
AshsZ
10:49:49 01/31/04
That's true plus you have extra buffer from the
11:06:26 01/31/04
subaru guys say >>
MaTT (90TT)
20:45:45 01/30/04
That's awesome man, can't wait to hear the results (n/m)
20:57:53 01/30/04
The other added beneift to H20 injection is that the
21:02:14 01/30/04
Thats awesome, so make me a kit already :) (n/m)
ZisLuv
21:19:55 01/30/04
