TwinTurbo.NET: Nissan 300ZX forum - Windshield washer fluid is being used as the "water" (n/m)
speedr300z (ATL)
on January 30, 2004 at 7:56 PM
Confused...what does the cost of windshield washer fluid >>
posted by I am Z-ing Double
on January 30, 2004 at 07:50 PM
Water Injection: "Just add water"; 1st trial run.
AshsZ
19:17:08 01/30/04
*inteerrreessttiiinnnnnggg* good luck Ash. (n/m)
Red ZX (Sr. N00b)
19:25:51 01/30/04
cool (n/m)
robo (sebring1970)
19:35:36 01/30/04
OK. Just got back. Running 25psi of boost, 22 degrees
AshsZ
19:44:14 01/30/04
I am Z-ing Double
19:50:39 01/30/04
Windshield washer fluid is being used as the "water" (n/m) -
speedr300z (ATL)
19:56:00 01/30/04
hmmmm...maybe that is what he is using (n/m)
Tennyson (ATL)
19:56:26 01/30/04
I think because he uses windshield washer fluid because
robo (sebring1970)
20:03:50 01/30/04
It will also fight corrosion (n/m)
SeedyROM (ZCON 2K4!)
20:12:24 01/30/04
Good point! With all this brass in the fittings and
AshsZ
20:30:09 01/30/04
Glycol is bad, it behave like sugar and will glue the
northZ
04:09:27 01/31/04
Its been getting down to freezing temps and I dont want
AshsZ
20:08:31 01/30/04
O.K., the freezing/alcohol thing makes sense. >>
I am Z-ing Double
20:33:32 01/30/04
There are no detergents in WW fluid that I am aware of.
AshsZ
20:56:23 01/30/04
the facts;
ni[X]it
22:46:25 01/30/04
really? I'll call this, "every DOGma has it's day" --->
robo (sebring1970)
06:38:02 01/31/04
Yup, it crystalizes in the liver when metabolized. BAD
AshsZ
07:44:41 01/31/04
the glycol shuts down the kidneys (renal), not the liver
robo (sebring1970)
17:51:28 01/31/04
i've had the displeasure of tasting both.
ni[X]it
10:18:31 01/31/04
most washer fluid doesn't contain any glycol, unless it's
robo (sebring1970)
17:25:31 01/31/04
am braking traction in 3rd gear on good tires
HakenTT
20:11:30 01/30/04
Well, I can see why you were able to run a stock ECU
AshsZ
20:19:07 01/30/04
That's true, with H20 it is necessary to run slightly
MikeH(Twin GT35BB Incon Z)
21:04:51 01/30/04
Good idea. This whole H2O thing is great for those of us
IBPimpn(Ca)
21:19:17 01/30/04
Agreed. I have been running H2O injection for over
Glenn (San Jose)
23:14:13 01/30/04
I need to do that. I can only run 13# @ 14degrees
IBPimpn(Ca)
23:27:27 01/30/04
that's counterproductive (n/m)
robo (sebring1970)
20:37:44 01/30/04
3rd (n/m)
RobWR14
20:38:49 01/30/04
wonder what you could do with h20 inj + race fuel (n/m)
RobWR14
20:34:35 01/30/04
what was the outside air temp today? (n/m)
Scotts94z32
20:54:42 01/30/04
That's the amazing part, its like 40 degrees out and
AshsZ
21:51:03 01/30/04
The Buck GN's here run H20 inj. all the time because
21:00:44 01/30/04
you'll have torque gains with more water,
ni[X]it
22:20:11 01/30/04
How do you figure that? More water may loose power
03:15:05 01/31/04
I think its not all about cooling, the volume of the water
northZ
03:58:21 01/31/04
Here is a link to water injection dyno testing
04:11:31 01/31/04
I wonder if someone will jump their ass for using STD
AshsZ
07:49:21 01/31/04
Ah, well in that case I think I will be adding more nozzles.
AshsZ
07:56:25 01/31/04
I am thinking of designing and running a staged
10:08:41 01/31/04
I have considered doing that too. But I'm leaning more to
AshsZ
10:49:49 01/31/04
That's true plus you have extra buffer from the
11:06:26 01/31/04
subaru guys say >>
MaTT (90TT)
20:45:45 01/30/04
That's awesome man, can't wait to hear the results (n/m)
20:57:53 01/30/04
The other added beneift to H20 injection is that the
21:02:14 01/30/04
Thats awesome, so make me a kit already :) (n/m)
ZisLuv
21:19:55 01/30/04
