TwinTurbo.NET: Nissan 300ZX forum - Why would the engine use more air at one side than another? (n/m)
northZ
on January 30, 2004 at 12:01 PM
I've noticed with the JWT dual pop at idle that
posted by MikeH(Twin GT35BB Incon Z)
on January 30, 2004 at 11:52 AM
Bad News..... Very Bad News
Shift_(ATL)
11:20:36 01/30/04
Re: Bad News..... Very Bad News
SR Productions ($65 stage 3)
11:24:54 01/30/04
a/f ratio BETWEEN about 3k and 4k rpms was between 16:1 and
Shift_(ATL)
11:29:09 01/30/04
You might still be okay. Is smoke pouring out
11:27:52 01/30/04
all i know is there were TWO puddles of oil on the floor
Shift_(ATL)
11:31:57 01/30/04
I think he mean that plugged PCV does make the
northZ
11:35:41 01/30/04
Seen it before. Check your PCVs and oil level.
11:35:46 01/30/04
Doesn't take much oil to cause a big puddle
SeedyROM (ZCON 2K4!)
12:47:57 01/30/04
Also, no smoke coming out the tailpipe...
Shift_(ATL)
11:34:27 01/30/04
=good news (n/m)
northZ
11:48:00 01/30/04
very good news (n/m)
11:57:53 01/30/04
If the dipstick blew, that's because of crankcase pressure
AshsZ
13:18:58 01/30/04
Shit bad news
northZ
11:28:06 01/30/04
Don't know...
Shift_(ATL)
11:33:26 01/30/04
This might be your problem right here.
Stealth021
11:39:40 01/30/04
Dual Maf are easy to set up on the AFC. Depends on
11:47:44 01/30/04
That sucks. Hopefully it isn't as bad as it looks. Good luck (n/m)
CaptK(ATL)
11:29:13 01/30/04
Likely because of the dual intake you have..
AshsZ
11:41:53 01/30/04
Umm... He has two MAS and smoke out the back.
FantasyZ
11:46:28 01/30/04
I meant no smoke out the tailpipes (n/m)
FantasyZ
11:47:16 01/30/04
Yeah, I saw that in his profile after my post. :)
AshsZ
11:53:27 01/30/04
yes it was...
Carlos Ramirez
08:08:45 01/31/04
11:52:44 01/30/04
Yep.. The DOOLZ also corrects that problem too.. (n/m)
AshsZ
11:54:15 01/30/04
Ash , what do you think of the blow through MAF
12:00:18 01/30/04
Why would the engine use more air at one side than another? (n/m) -
northZ
12:01:07 01/30/04
Velocity, pressurization, intake pulse, etc.
Stealth021
12:08:57 01/30/04
The Z has a split plenum or dual plenum design
12:15:47 01/30/04
Mostly to do with exhaust manifold difference and
AshsZ
13:00:08 01/30/04
Thanks for the knowledge you sharing
northZ
12:22:12 01/30/04
You should check both side while cruising and WOT
12:49:38 01/30/04
I dont think this statement is 100% correct
TARGETZ
13:26:52 01/30/04
also the motor had like 170+ k on it. (n/m)
Halo Z
14:59:14 01/30/04
True, but good compression is good compression
Shift_(ATL)
01:14:28 01/31/04
Also check all your spark plugs for signs of detonation
12:02:02 01/30/04
Check your PCV valves.
Marshall
12:19:06 01/30/04
I wish it were just pcv's, but i just had them replaced. (n/m)
Shift_(ATL)
01:12:41 01/31/04
It could still be the PCV's
Marshall
13:31:19 01/31/04
thanks for blowing up my car man.
JustinZTT-ATL
15:32:44 01/30/04
LOL...
Shift_(ATL)
01:16:32 01/31/04
Good luck man (n/m)
EricTTZ
17:00:28 01/30/04
