TwinTurbo.NET: Nissan 300ZX forum - top of cams, inside oil filler cap, spark plug cavities
schuss
on January 08, 2004 at 11:11 PM
which internals, exactly, can you see? (n/m)
posted by Spee
on January 08, 2004 at 05:55 PM
(just little stuff - will no more later)
624 lbs of hard work and potential
schuss
02:18:03 01/08/04
Is it really 624lbs?
Southern_Z [IL]
02:23:23 01/08/04
according to the shipper, yes. 624 lbs of turbo love! (n/m)
schuss
15:39:53 01/08/04
US or JSpec? Looks pretty clean, good luck with the install (n/m)
Stangz88 (Coming soon)
02:33:48 01/08/04
jdm 90-93 (n/m)
YugoBernie (NoVA)
02:49:17 01/08/04
How can you tell? Just curious (n/m)
10:57:17 01/08/04
It has JDM down pipes on it, so it's clearly an
YugoBernie (NoVA)
11:40:10 01/08/04
Don't forget to swap oil pans. (n/m)
YugoBernie (NoVA)
02:48:28 01/08/04
2nded (n/m)
BCs300z
02:52:55 01/08/04
Why? (n/m)
Madhatter10-6
06:25:55 01/08/04
624lbs on an oil pan (n/m)
MaTT (90TT)
07:05:34 01/08/04
Bouncing up and down on a truck for several hours..... (n/m)
Dave N
08:39:31 01/08/04
Never mind the month spent on a boat doing the same thing. (n/m)
YugoBernie (NoVA)
10:41:51 01/08/04
Should he make sure the pickup isn't damaged as well? (n/m)
MaTT (90TT)
07:06:15 01/08/04
Yup. (n/m)
YugoBernie (NoVA)
10:42:13 01/08/04
Oil sender on wrong side..and the pan is probably bashed up
jcm3
07:05:30 01/08/04
There are *lots* of other things that need to be changed:
therinL
08:23:29 01/08/04
Not lots... maybe 5-10 items at most...
KaZ (VaBch)
08:27:50 01/08/04
The first 12 items off the top of my head:
therinL
08:56:54 01/08/04
Re: The first 12 items off the top of my head:
Guapo
09:10:52 01/08/04
i would think the coil packs are fine, esp on low mile motor
ScubaSteve
10:07:44 01/08/04
Balance tube differences:
therinL
10:21:14 01/08/04
Balance tube bolt pattern is different on engines coming
YugoBernie (NoVA)
10:46:25 01/08/04
it looks to be the same
schuss
15:41:11 01/08/04
Agreed - the 300ZX plenums JDM or US have the same mounting
YugoBernie (NoVA)
21:59:29 01/08/04
brake booster is on the left side overseas
KaZ (VaBch)
11:53:45 01/08/04
Re: Re: The first 12 items off the top of my head:
therinL
10:18:58 01/08/04
Re: Re: Re: The first 12 items off the top of my head:
Guapo
11:52:57 01/08/04
Wasn't there a "sticky" in tech a while ago on this? (n/m)
TTony
13:02:50 01/08/04
as for down pipes, of someone is doing a convertion no.
Halo Z
10:24:49 01/08/04
Absolutely:
therinL
10:29:42 01/08/04
*Since.
YugoBernie (NoVA)
10:47:07 01/08/04
give it up. (n/m)
Halo Z
12:00:19 01/08/04
Does it really pain you so much to learn 1 word? (n/m)
YugoBernie (NoVA)
12:59:58 01/08/04
Well... having done this over 3 years ago... a few times >
KaZ (VaBch)
11:49:21 01/08/04
Where did you order your motor from?/How much did you pay? (n/m)
max240
07:31:49 01/08/04
yes, it's JDM - you guys are good! ;)
schuss
15:38:14 01/08/04
Spee
17:55:43 01/08/04
top of cams, inside oil filler cap, spark plug cavities -
schuss
23:11:58 01/08/04
