TwinTurbo.NET: Nissan 300ZX forum - Not out of line with what I found untuned at low boost >>>
Subject Not out of line with what I found untuned at low boost >>>
Posted by Mike (Austin) on November 05, 2003 at 5:40 PM
  This message has been viewed 55 times.
In Reply To My first TTZ dyno results... posted by Carp (Show & Go) on November 05, 2003 at 03:04 PM
Message I dyno'd with my old 16G setup with a single pop,no AFC, 555s, untuned at 1 kg/cm2 and did 426/391. I later added the AFC, dual POP, dual MAF and tuned (also went from 2.25" Borla to 3" B&B) and tuned to 441/400 at 1 kg/cm2. This was all on a stock, unopened motor/heads/cams, 15 degrees base timing, pump gas, SAE numbers.
Next go-round was the built motor/heads/cams/16Gs - 1.2 kg/cm2 (17 psi), pump gas, 15 degrees base timing, JWT program, tuned to 11.8 A/F, 533/482 SAE. Did 532/491 SAE with same parameters about 3 months later at ZCon.
I have the charts at home and can upload/e-mail if anyone is interested.
I'd like to see in the neighborhood of 560-575 RWHP out of my 18G setup on pump gas tuned with the cam gears. We will soon see.
