TwinTurbo.NET: Nissan 300ZX forum - 1 is a tension rod bushing, replace both. 2-4 look like
thunderZ
on October 08, 2003 at 11:36 PM
leaks and joint problems..missing parts. argh.
posted by maxl(Indy)
on October 08, 2003 at 11:16 PM
a starter bolt, but I can't really tell. #5 could be from a few things. That's right under the oil line for the pass side turbo feed, and also the valve cover above it could be leaking. Clean it up and check again later.
maxl(Indy)
23:16:42 10/08/03
1 is a tension rod bushing, replace both. 2-4 look like -
thunderZ
23:36:34 10/08/03
umm looks like an NA. (n/m)
EricTTZ
23:39:19 10/08/03
A Bright Red 1990 NA coupe,, lol ;)~ (n/m)
ZBlacktt
23:41:58 10/08/03
1)T-rod bushings, 2)Missing Starter Bolt, 3)leaky Valve cvr (n/m)
Bobby12many
23:43:26 10/08/03
Can you explain the role of the starter bolt please? cvr = ?
maxl(Indy)
23:44:20 10/08/03
valve cvr = valve cover (n/m)
EricTTZ
23:46:15 10/08/03
It attaches the starter to the car (which is a good thing) (n/m)
Dave N
23:46:37 10/08/03
ummm..... the bolt holds the starter to the trans (n/m)
EricTTZ
23:46:43 10/08/03
Regarding the starter bolt:
maxl(Indy)
23:56:50 10/08/03
Nut on top
EricTTZ
00:13:26 10/09/03
I was told that with one of the bolts missing-
MaTT (90TT)
07:16:06 10/09/03
look for yugobernie's posts in the classifeds for the
3 double-0 ZX(Va Bch)
00:14:23 10/09/03
PIC 3 - with the yellow writing on the shield/cover?...
l3adl3oy-Z
09:19:52 10/09/03
