TwinTurbo.NET: Nissan 300ZX forum - Uh yeah. That's not a trick question to test my knowledge
Subject Uh yeah. That's not a trick question to test my knowledge
Posted by SpeedyZX on September 30, 2003 at 11:58 AM
  This message has been viewed 107 times.
In Reply To is it necessary to change out the brake fluid periodically > posted by stockplayerz (NYC) on September 30, 2003 at 11:48 AM
Message is it? ;-P Anyways, the brake fluid should be clear not black. You can bleed it yourself as it is a DIY if you have someone to help you bleed the brakes. If the brake fluid is low, check the pads to see how much material you have left. If they are low, change out the pads (also DIY) but I recommend having the rotors turned as well. Change the fluid.....
Click here to e-mail me!
Click here for My Homepage
