| Message |
: section... you should unscrew the gas cap, pull the fuel pump relay, start the engine, it'll die, crank it a few more seconds. : : if u can let you car sit for a day or so it helps. it lets down the fuel pressure so u don't shoot gas all over. also u might want to use a hair dryer to heat up the rubber line to lossen it's grip on the hard line. the bracket that holds AC lines might cause some trouble on the pass side. some take it off and some can bolt over it. if u need to take it off, just try to bend the bracket (with the line off of it ) back and forth.
RIC my spelling sux 1993 Onix Black over Tan NA if people would read the FAQs life would be good, and admin wouldn't have to delete a ton of posts
 Farfignugan means "Can't fly"
 FLA, GA, & Tex
