TwinTurbo.NET: Nissan 300ZX forum - the proper way to relieve the fuel pressure is in the TECH
Subject the proper way to relieve the fuel pressure is in the TECH
Posted by Bernie on December 22, 2000 at 7:04 PM
  This message has been viewed 36 times.
In Reply To PIA gettting the fuel lines off posted by Ric (Halo Z) on December 22, 2000 at 04:21 PM
Message section... you should unscrew the gas cap, pull the fuel pump relay, start the engine, it'll die, crank it a few more seconds.
: if u can let you car sit for a day or so it helps. it lets down the fuel pressure so u don't shoot gas all over. also u might want to use a hair dryer to heat up the rubber line to lossen it's grip on the hard line. the bracket that holds AC lines might cause some trouble on the pass side. some take it off and some can bolt over it. if u need to take it off, just try to bend the bracket (with the line off of it ) back and forth.
Bernie
Authorized sales rep for...
Datalogs every run... launches with boost in your 5-speed...
keeps turbos spooled between shifts... enables controlled power slides...
valet mode prevents abuse of your Z... unlike most factory systems, maximizes acceleration!
For more information, pricing, or to purchase a system,
feel free to e-mail me: bhsiao@newssun.med.miami.edu
or visit the website
